Aluminum Radiators ?
RE: Aluminum Radiators ?
what do you guys think about this from ebay - 2 row aluminum with built in electric fan with nice shiny shroud - nice bling factor
Item #300023079500 http://cgi.ebay.com/ebaymotors/64-66...QQcmdZViewItem
If you want the perfect fit and the awesome functionality/reliability/repairability of the good aluminum radiators, then pony up and buy one.
I have a BeCool in the GTO, that thing used to run 220-250 all the time in Charleston SC. I put the BeCool in there with an electric fan on a thermostatic switch, and it rarely if ever gets over 190, since that is where the fan is set to kick on. The high end ones are a bolt in deal, no fab work at all. For $500+ it should be that simple.
Cheaper means more work for you to do. if you can do it, then buy the cheapies. I have one in the race car and it works great. if it can keep a 700hp 467ci drag engine cool while sittin in traffic, it can surely keep your mild 289/302 chilled... with the right fan and a trans cooler if you have an auto. the drag car has a HUGE cooler with its own fan on it, since the radiator doesnt have a cooler built in.
I second that.... The cheepo's also may not be of the same manufacturing process as well. The good radiators are true direct-fit, bolt-in replacement. There will be no modifications needed for install it, my installation went great and everything fit like it should even the fan shroud. Also, some cheepo radiators use epoxy to seal some parts of the radiator.
ORIGINAL: THUMPIN455
ORIGINAL: rmodel65
i just got an alum radiator for the 65 for 319 bucks from jegs it was adirect bolt in from northeren radiator
Well, I don't have an aluminum radiator, and I live in hot Texas. I do have a 4 row copper core rad though, and my car runs cool as a cucumber with the air con on in standing traffic. The best mod I have bought for it has been the shroud and overflow tank. Cheap insurance.
