Okay here's the deal. I got this car about two years ago and the horn didn't work. I didn't worry about it too much because I'm not required to get inspections here in Idaho, but I'm moving back to texas and will need the horn to pass inspection when I get back. It's got tilt steering and a lecarra steering wheel on it. I've already checked the horns they work when supplied with power. And have changed all the fuses I can think of. Anyone else have Ideas, or am I going to have to do this the hard way and follow each wire all the way to the horn button?
Yeah, Its probably that little spring button thing that goes bad. Try to ground it out yourself at the steering wheen and see if that works. It could also be a bad horn relay.
