Cleaning Cooling system
I removed my water pump this weekend that hadn't rotated in 30 years. No water left, just rust and scale. Is there anything I can spray on the timing cover that the pump mounts to to plean the corrosion off. Luckily the radiator still holds water well.
RE: Cleaning Cooling system
ORIGINAL: Brandontyler65
well i had my water pump go out and i was in a pich and autozone was the closest people that had one and i got the duralst one that is $50 and i am surprised it worked really well
Autozone usually has several water pumps to choose from. I purchased the remanufactured model last year as replacement. Painted it up and installed w/o a prob. Been working great. Also, don't forget to get an Autozone punch card while you're there. After 5-$20 purchases you can get a free $20 gift card...every little bit helps when trying to keep these older cars running.
I really need to clean up the whole system. I will buy a new pump at autozone (the lifetime warranty one is like $30) but I need to remove all the junk that is in the system. I am thinking about getting the garden hose and a nozzle and just flushing as much out as I can.
be careful i did that once and it blew threw an intake gasket i dunno if the pressure was too much or not but it was that factory one (on a diff motor) i get the prestone super clean and use that in there for bout a week or i go to the local shop and spend the bills to get it powerflushed by them but thats cause i am lazy
09-10-2015 08:39 PM
