Water Pump Question
Old 09-10-2006, 09:17 PM
Toddman0025
Toddman0025's Avatar
Default Water Pump Question
I'm not very familar w/ the mechanics of the water pump - I removed the PS pump when I converted to MS, and just pulled fan and water pump pulley in order to install an electric fan. So now there are no belts going to be driving the water pump. How do people get around this ?
Toddman0025 is offline
Old 09-10-2006, 09:56 PM
Toddman0025
Default RE: Water Pump Question
or am I thinking about this completely wrong and the water pump is not belt driven?
Old 09-10-2006, 10:03 PM
tylerdru
tylerdru's Avatar
I think you just put the pulley back on with some smaller bolts
tylerdru is offline
Old 09-10-2006, 10:04 PM
Toddman0025
OK so the water pump is not belt driven? What powers it then, the camshaft?
Old 09-10-2006, 10:06 PM
tylerdru
tylerdru's Avatar
Put the fan pulley back on the water pump. It is belt driven. The same belt powers the water pump and fan.
tylerdru is offline
Old 09-10-2006, 10:10 PM
Toddman0025
Since I no longer have a power steering pump I need a belt that just runs to the huge pulley below the fan right?
How do I go about sizing a new belt for that?
Here's the old setup, but now the fan and power steering pump are gone (the belt went from main pulley --> PS pump ---> fan)...
Old 09-10-2006, 10:25 PM
Soaring
I ♥ Acer
Soaring's Avatar
Yes, the water pump is driven by a belt. Since you no longer have the PS pump to deal with, just get a belt that will operate the alternator and the water pump coming off the main pulley. Just go to autozone and explain what you want, and they will most likely have the correct belt.
Soaring is offline
Old 09-10-2006, 10:26 PM
Toddman0025
ok that sounds easy - there's two free spots on the main pulley - should I run it in front or rear? (alternator is in mid)
THANKS FOR THE HELP !!!!
Old 09-10-2006, 10:36 PM
Soaring
I ♥ Acer
Soaring's Avatar
Put the belt where it matches both the alternator and the water pump. They should be on the same groove. Here is a pic of mine.
[IMG]local://upfiles/10034/5E1CB3378C964924B01B9D83CB274012.jpg[/IMG]
Soaring is offline
Old 09-10-2006, 10:38 PM
Toddman0025
ok so rather than having one belt running the alt and one running the water pump just get a giant one to go around them all ?
Quick Reply: Water Pump Question
