66 mustang problem help
Old 09-11-2006, 06:45 AM
twistercuzz
twistercuzz's Avatar
Default 66 mustang problem help
hi i have a 66 mustang that when i drive it on the freeway whenever i hit a dip the car wants to vere to the right side dangerously so can some one help me on waht to check for or what to do plz thanks
twistercuzz is offline
Old 09-11-2006, 09:38 PM
Gun Jam
Moderator
Gun Jam's Avatar
Default RE: 66 mustang problem help
All new upgraded suspension, with 1.25" - 1" front/ rear anti sway bars, kyb/kony shocks, 600-650 lb front lowering springs, 1" lower and stiffer rear leaf springs, montycarlo bar,
That would really make your day. If you dont have the $$$$ for it then probably new (original type) shocks, ball joints would probably help a lot and adding a 1.25" front and 1" rear antisway bar would also help A LOT.
Could be something else but that’s my guess based on what i know.
Gun
PS: when you are out side the car and you use your arms and upper body to force down heavily on a fender above a wheel once then let it bounce back up does it take more effort on the front right than the front left? Does it oscillate up and down for a second or does it stop once it reaches the top of the return bounce?
Gun Jam is offline
FD725
08-23-2015 06:43 AM
jjwinel78
08-17-2015 03:34 PM
KEM Motorworks
08-14-2015 10:13 PM
daytooday
08-11-2015 09:22 AM
philster0306
08-10-2015 11:33 AM
Quick Reply: 66 mustang problem help
