turn signal lights stopped working
RE: turn signal lights stopped working
Could be the turn signal mechanism in the steering column.
ORIGINAL: mlhaycraft
My turn signal lights stoped working. My hazards however still work. I thought that maybe it was the flasher itself but would my hazards still work? ANy sugestions?
can you hold up the lever and it still works? its prob the turn signal cam if its that...
i still wouldnt count it out if it just totally dosent work but it dosent prove it....
if you decide to fix the turn signal lever type deal...i highly reccomend buying the whole assembly and not just the "repair cam". its a big pain and it didnt fit or work right for me...so i ended up paying for both like an idiot.
same thing happened to me. Replaced all bulbs, flasher unit, traced down what wires i could see and nothing helped. Ended up taking it to an auto electric shop and it was a bare wire under the dash.
I'm not sure what year Stang you have but on my 68 Mustang I had the same issue. The hazzards worked but the turn indicators did not. It ended up be the blinker unit. On a 1968 the hazzard and the turn indicators have seperate blinker units. This could be your issue too.
ORIGINAL: 68pony5
Could be as simple as a turn signal flasher gone bad. Check that out first. If you recently removed the steering wheel than there may be a prob with the turn signal assembly unit with a short or bad wiring. Check it out secondly. Might even be a loose wire in the harness assembly. Give it a try...good luck!!!
Sean W.
The hazzard and turn blinker unit are interchangeable. The orignals are different P/N but the replacment work for both. If mlhaycraft takes the working hazzard blinker out and puts it in the place of the turn signal blinker it will tell him real quick where to focus and weed out the blinker unit. This what I did. Sean....thanks for the nice feedback of my black 68 pony pics.
