alternators
RE: alternators
I have a 1-wire. I had already removed the entire harness from the engine bay when I made the swap. Basically, you'll just need to remove anything that connected between/to the alternator and voltage regulator. The only remaining connection will be between the alternator and the battery...and make sure you have 2 gauge or better wire.
Also, beware that the alternator is bigger than the stocker. I had to use a grinder on some mounting bolts in order to get the alternator to move properly. I also had to move my dipstick to the other side of the alternator mount.
Also, this alternator will pull your engine down like nothin' else. You'll want to underdrive it (bigger pulley on the alternator, or smaller on the crank). I dropped mine 20% and it still makes a noticable difference at idle when it has to pull to keep the headlights bright.
RE: alternators
hey,
i had bought a 1-wire alternator form summit racing, but it shorted out. The reason it shorted out was becuase the power stud on the back was so long that it hit the engine block and shorted. i found this out at a car show when the car just died on me. The 1-wire alternators are easier to install(because its only one wire ), but you have to rev your car to get them to start charging. i switched back to a 3-wire and i like it much better. What are you running that you need a 160 amp?
RE: alternators
Why in god's name do you need a 160 amp alternator?? You running some BIG stereo amp or something? You should be fine with a 100 amp even with some added accessories.
ORIGINAL: ADRIAN1
doea anyone have a one wire alternator? im going to get a (Power master) 160amp alt. from summit! i currently have a stock style alt. and want to know how you guys made the change?
RE: alternators
ORIGINAL: slickman
ORIGINAL: ADRIAN1
If I were you, I would add up all the amps you will need at one time during the night.
1. Head lights
2. rear and interior lights
3. Stereo at full blast
4. Engine and VR/Battery charge
Then see what you realistically need. I guarantee you that you will not reach 100 amps draw no matter what stereo you have. Here's something else you may want to consider.
When upgrading to a higher output alternator you should always install a larger wire between the alternator and battery. Even with a standard output alternator you will get better performance and life out of your alternator if you upgrade the main battery wiring. The original wire just isn't large enough for proper power transfer.
If you are using your alternator to it's maximum output or when you upgrade to a higher output Alternator you must increase the wires size. An alternators ability to send the power it is making to the battery is directly related to the wire size and quality of connection between the alternator and battery.
Also, a wire that is to small when used on a high output alternator can cause the power to back up within the alternator making it overheat, burn up and fail.
Another area that little is paid attention to is the ground. You must also improve the ground as well. A poor ground will hinder the alternators ability to send power to the battery and can burn an alternator up just as fast as an inadequate alternator to battery wire. Your ground may be fine when you first install your alternator but over time corrosion and resistance builds up in the ground connections. This is why it is best to run the ground directly from the rear of the alternator to the battery.
RE: alternators
Same animal. Anything over 100 is pushing your wiring to the limit. If you have not changed out the engine harness to an upgraded harness, then you are asking for trouble with that high of an amperage alternator. Think about it. Your old wiring was designed for less than 50 amp alternators, and that was when the wires were new.
RE: alternators
you can get a ford 3rd gen alternator which is a 1 wire setup and they look nice cause it has a internal fan and they produce 130A easy and with a simple diode upgrade you can go 200A+ so thats what i would do
