Valve Number Sequence
Old 07-02-2003, 11:40 PM
71Mach1
71Mach1's Avatar
Default Valve Number Sequence
I have a 1971 Mach 1 in need of some timing adjustment, and am looking for someone who can verify (or at least point me to where I can obtain) the location of the #1 valve on a 351C. Thanks in advance.
71Mach1 is offline
Old 07-03-2003, 05:46 AM
6Stang7
6Stang7's Avatar
I am almost 100% sure that it is front valve(cloest to the radiator) on the passanger side. Can anyone varify this?
6Stang7 is offline
Old 07-03-2003, 09:30 AM
nostang
nostang's Avatar
there is no valve that is called the number one valve,the number 1 cylinder is passenger side front,but i don't know why you would need to know about the valves to set timing.
nostang is offline
Old 07-03-2003, 10:21 AM
71Mach1
71Mach1's Avatar
Excuse me for refering to the #1 cylinder as "valve", inexcusable slip up on my part. You have to connect the timing light to the #1 spark plug wire to adjust the timing is why I ask.
71Mach1 is offline
Old 07-03-2003, 06:02 PM
6Stang7
6Stang7's Avatar
Ok, well #1 cylinder is on the passanger side closet to the radiator.</P>
The numbering order is</P>
4 8</P>
3 7</P>
2 6</P>
1 5</P><edited><editID>6Stang7</editID><editDate>37805.6690625</editDate></edited>
6Stang7 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
svfetter
10-05-2015 11:39 AM
69Volunteer
09-30-2015 10:39 AM
lmurf60
09-24-2015 10:07 PM
Quick Reply: Valve Number Sequence
