Loosing RPMs when i press the brake **Update**
Old 10-03-2006, 08:40 PM
  #21
Mustang Boy
Mustang Boy's Avatar
Default RE: Loosing RPMs when i press the brake
i didnt have time yesterday to try anything out cause i was busy doin other stuff so i had to drive it to school today the way it was only to find out thid morning that may car wont idle at all which made it even more fun to drive and it was the same thing on the way home so im gonna go outside in a few minutes and mess with the carb and the timing to try and get it to idle
Mustang Boy is offline
Old 10-03-2006, 11:14 PM
  #22
6mustang6
6mustang6's Avatar
yeah, i thought that at first too, Tyler, Thats why i asked if he did it with the car sitting. Get that idle adjusted right first, then lets work with the other problem, which i suspect to be electrical.....
6mustang6 is offline
Old 10-04-2006, 12:00 AM
  #23
Colorado_Mustang
Colorado_Mustang's Avatar
Unless you have a very radical cam, you need to get that idle back to where it should be before doing anything else.
ORIGINAL: Mustang Boy
yea i have the idle set at 1400 itll idle below that rpm its just not a very smooth idle
Colorado_Mustang is offline
Old 10-04-2006, 10:27 AM
  #24
Mustang Boy
i got a cam a little more radical than this http://www.classicinlines.com/prodde...268%2DHDP%2D10 but i cant get the exact specs cause they no longer carry the cam i have
and i got the problem fixed it turns out the bolt holding my dizzy still got loose som how and i adjusted the timing a lil this morning before i left for school and it purrs like a kitten now but i didnt get a chance to get the bolt tight cause like i said i was on my way to school and didnt have time to look very well for a 1/2in wrench cause i was in a hurry but im pretty sure i know where a half in wrech is in my car and ill tighten it down after school and maybe advance the timing a little more
Old 10-04-2006, 11:50 AM
  #25
rigwelder
rigwelder's Avatar
alot of what everybody has said makes good sense. but you have it idled up to high. my 69, idles down when i turn the headlights on. not enough to bother me though. i havent read everybodys post??? but when its idled right and pushing the brakes in makes it die. thats alot of times just a simple vacum leak, why dont you get out there one night when its dark and crank the old beast up and look under the hood and see if its jumping fire from the plug wires anywhere! just look for the little sparks. anyhow if you have to idle at 1400 to keep it running the problem could be just about anything!! wiring,plugs,vacum,carb and a few other things im sure!!!! find some old shade tree mechanic and ask him what he thinks. the older and wiser mechanics know these old v-8"s
rigwelder is offline
Old 10-04-2006, 06:09 PM
  #26
Mustang Boy
i forgot to tell i have no V8 this is an I6
and the prob is solved
Old 10-04-2006, 06:38 PM
  #27
Soaring
I ♥ Acer
Soaring's Avatar
Default RE: Loosing RPMs when i press the brake **Update**
Well, Duhhhh! If the dizzy hold down bolt is loose you will get all sorts of crappy engine running problems. I assume you know to use a special tool to tighten that bolt down. Here's my trusty dizzy hold down bolt wrench.
[IMG]local://upfiles/10034/3F77F64D85C947A4B1C7D108FA70E654.jpg[/IMG]
Soaring is offline
Old 10-04-2006, 08:46 PM
  #28
Mustang Boy
well luckily for us I6 guys the bolt is easily gotten to with a regular old half in wrench which is wut i used to tighen it down with in my school parking lot
Old 10-04-2006, 08:54 PM
  #29
Soaring
I ♥ Acer
Soaring's Avatar
Yep, there are noticeable differences between the 289 and the I6, huh? That is one of the most simple engines in the world to work on.
Soaring is offline
mtgldr
02-03-2024 09:00 PM
10-07-2015 07:02 PM
musnicki
09-23-2015 07:11 AM
Daddys Girls GTs
09-14-2015 08:46 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Loosing RPMs when i press the brake **Update**
