dash lights
Old 10-10-2006, 12:53 AM
6mustang6
6mustang6's Avatar
Default RE: dash lights
yeh, it could definatly be the dimmer in the switch. I'd check that, and the ground wire on the instrument panel.
6mustang6 is offline
Old 10-28-2006, 02:40 PM
Joe Mama
Joe Mama's Avatar
Man, I am SOOO glad that I found this post, as I was having issues with the dash lights as well. My headlights and taillights worked fine, but the dimmer switch sounded horrrrrible when you rotated the ****. (And of course I had no dash lights) Well after getting the wrong switch in the mail, my local auto parts store had the right switch in stock.
I wonder how I had lights at all with this switch.
[IMG]local://upfiles/49941/CCC25437565B4F688916935BA002A903.jpg[/IMG]
[IMG]local://upfiles/49941/D5AF03241CA448B0AB881A16E297D95C.jpg[/IMG]
Joe Mama is offline
Old 11-06-2006, 12:28 AM
rumblestang
rumblestang's Avatar
well guys i want to thank you a lot for the help i can now see at night because i have dash lights. fixed it for twenty bucks and half an hour of workin on the lights and that was it.
rumblestang is offline
Old 11-06-2006, 01:25 PM
superdavid
superdavid's Avatar
Any time any of your lights give you trouble immediately suspect the headlight switch. They over heat and freak out like crazy. I've gone through 4 of them in the two years I've had my 67 stang. Every time I replace that switch my problems go away.
superdavid is offline
Old 11-06-2006, 03:27 PM
Brandontyler65
I ♥ Acer
Brandontyler65's Avatar
then add a relay setup into your headlight system cause i had the same prob so thats what i did now i am on the same switch i did it in my truck and my car a cheap worth wile upgrade
Brandontyler65 is offline
folivier
10-02-2015 05:34 AM
jc409
Convertible Tech
09-26-2015 08:28 AM
09-25-2015 09:06 AM
accarter
09-21-2015 11:56 PM
2015Ecoboost
09-17-2015 01:48 PM
Quick Reply: dash lights
