dash lights
dash lights
guys i have a 66 and the dash lights went out. My headlights work and the red dot that comes on with the high beams work but no dash cant see anything i pulled the dash off when i replaced it (which i have to do again now) could i please get help on what the problem could be.
RE: dash lights
Prime suspect here may be the headlamp switch itself. Check for loose connections to the switch and try cleaning it up with some electronic spray cleaner. Otherwise, you might need to buy another headlamp switch. Here is a link with pic...good luck..keep us posted on your progress..
http://johnsmustang.com/Parts/details-4685.html
RE: dash lights
ORIGINAL: v6h.o.pony
you blew a fuse
you blew a fuse
RE: dash lights
Sometimes the brass connections in the headlight switch get corroaded and the little terminal clip which rotates with the headlight switch and does not make a good connection. I was able to clean the switch up and bend the clip to place more pressure on the contact spring. I know, it's tough to explain without good details from the pic but once you remove the switch, you will see what I mean...
[IMG]local://upfiles/19071/7C6A55C0457340B1A5AA8EBD911316DA.jpg[/IMG]
