Can I replace this?
RE: Can I replace this?
ok, from what ive heard from being on these boards for a while is that those cowl vents were a real pain in the @$$, numerous people have complained that it gets so rusted underneath the vent becuase water gets in there and just sits. they guy who had it before you probably was trying to resolve that issue and either sealed it before it got bad, or fixed it then sealed it. id leave it alone unless u really really want AC.
i have replaced the undeside of the cowl panel on my 65. i had to remove at least 100 spot welds it seems and the "fillet" the panels apart, after that it really wasnt that bad, i too am shaving my cowl vents. i think it will looks smooth in the end, the handles, locks, emblems are all gone aswell. but the cowl vents are NO easy task
The cowl vent not only allows outside air into the cabin, but also supplies the air to the heater so that you get heat and defroster. You may not want or need the vent, but you will need the heater and defroster to be working especially during the winter. And yes, you can install an aftermarket air conditioner, but it won't give you warm air during the winter. If it were mine, I would replace the cowl vent and repair the cowl if necessary.
Not only is this car sweeeeeeeet!, But check out the custom cowl set up...i was gunna seal mine up but now my brain thinkin on what different approches you can do with a little fab work. I don't like to copy fab work but if i do this it will be similar..
http://www.mustangandfords.com/featu.../photo_15.html
MC,
you are correct sir. That car is phenominal. If I sold my house, and cashed out my 401K, and sold my plasma, sperm, and kidneys I might me able to afford something like that. Until then it looks as if I'll be getting to know the sander and ratchet a little better. But thanks for the input guys, you've definitely given me options.
