intake manifold removal
OK quick question on my 289 i have a intake manifold gasket leak and am replacing it as we speak i am about to pull it off but i am afraid that when i do coolant is going to flow strait in to my intake ports on my head will this happen sec. when i put the new gaskets on will i need to use any silicon.
thanks, Mitch
thanks, Mitch
RE: intake manifold removal
Read through this, then get back if you have more questions.
http://www.edelbrock.com/automotive/...ral_instr.html
OK well i get all that stuff i am just afraid of coolant getting in to my head will that happen or are the jackets located some were the coolant cant reach the intake ports
You have to drain your radiator before you remove your intake manifold! Otherwise you'll have coolant everywhere. I never had to change my oil after replacing my intake manifold gasket. Also, only use blue rtv sealant on the ends of the manifold, don't use those cheap end gaskets they give you. Make sure you use enough sealant to fill the gap.
