dropping the oil pan?
RE: dropping the oil pan?
when you are ready to pull the pan, make sure it is full of oil and you are right underneath it when you unbolt it
I did that, cept it was with the transmission[:@] got coverd in trans fluid....it as great
Did the auto tranny thing the first time I did a car on a lift. I had never done an auto tranny fluid/filter change and I didnt' know they are pulled full. I was standing directly underneath it when it gave way [&:]
ORIGINAL: Sean W.
The anti-sway bar is in front of the pan, and is not in the way. The crossmember bar is definitely in the way, and only requires the removal of two bolts. Oh, the starter has to come out too. Check the pic.
[IMG]local://upfiles/10034/DB33CBCABE80499A90E2AF4F28033267.jpg[/IMG]
how come you have a blue pan?
ORIGINAL: Soaring
ORIGINAL: earlymustang
ORIGINAL: Soaring
ORIGINAL: Sean W.
drain the oil first.
drain liquids first before removal, Duh Sean!
