73 mach1 shifter question (automatic)
iam trying to replace my the aftermarket B&M cable shifter on my m-stang with the an orginal shifter (i got one on ebay..whole assemble minus the linkage). i was wondering what the linkage assembly looked like? and if there were different ones for the type of trannie supplied. (my car orginally came with an fmx but i have a C6 in there now. hopefully i can make it work. thanks!
[IMG]local://upfiles/25288/A969135B0C2E483584E16525F0985428.jpg[/IMG]
RE: 73 mach1 shifter question (automatic)
I don't know about the linkages, but you should be able to find them on eBay. I do know that the actual shifter itself did not change from the late 60s through 73 depending on the tranny. IE the FMX and C-4 had the same shifter, the shifter you bought should work with the c-6 if you get the right linkage
thanks jes, will definately be on the look out on ebay. i found one pic in all my searches and think i can make a linkage out of some tubular stock i have if i cant find an actual one. thanks again!
They are solid steel bars, bent in just the right places and one end is adjustable. I dont see why it wouldnt work with a C6, the shifter quadrant is in nearly the same spot as the FMX. If I get outside today and can find mine, I'll take a pic of it for you.
thump,
hey appreciate it man! no rush on the pic, iam awaiting my shifter from texas, also can you tell me where the linkage attaches to on the trannie. i have some adapter on it for the cable shifter and wonder where to attach the linkage to. again thanks
james
james
I sure do take a bunch of wierd pics for this forum. Chargin up the ol digicam right now.. lol. hey why dont you guys come up and cut/stack/split some firewood? Then I can get more work done on the POD's..
ORIGINAL: THUMPIN455
mungodrums
10-07-2015 04:01 AM
