How should I...
RE: How should I...
I don't usually recommend jacking up a classic mustang by the rails, but if you use a 2X6 piece of lumber between the jack and the frame rails, you will be OK. With it in the air, you are not likely to have anything move while the crossmember is being removed. If you are removing it to get the oil pan off, you are going to have to jack it up anyway.
RE: How should I...
The car is currently on jackstands so I wont need to jack it up. The engine is in it so wouldnt the mounts and engine hold it in the correct spot? I forgot about the engine holding it..
Thanks
Thanks
qball
5.0L V8 Technical Discussions
06-18-2011 12:18 PM
