automatic to manual-possible
i have a 69 coupe that is an automatic. i am beginning to like the idea of driving a manual, however, i dont know if ts something i want to try to attempt. has anyone done this or know anything about the amount of work involved.
RE: automatic to manual-possible
its extremely possible and the most likely route you will wanna go is a T5 swap. search the forums for more info on this swap....i think theres a few stickys or soemthing about it too....
its easy!!!! the t-5 would probably work behind a 289.302,351w and maybe the clevland and modified? it will fit right in there. but be sure a plug the coilent holes in you radiator. But theres and old wise saying that works very good in life! (thats if the automatic is good) IF ITS NOT BROKE - DONT FIX IT! but its yours, do what you want!!!!!!!!! a top loader from a earlier fox body stlye gt might work too, then there would be no linkage to fool with.
Plan on spending about $3000 if you're buying all new parts and want a hydraulic clutch. Check out Modern Driveline. I bought all my own stuff, but I wish I had bought a kit from them.
It can be done and fairly simple as well. Assuming you have some mechanical skills. Look in the FAQ section. There are a couple of links to articles telling you exactly what you will need.
Good luck.
Good luck.
