Affordable Air Compressor???
Old 10-23-2006, 04:28 AM
Shifty101Easy
Shifty101Easy's Avatar
Default Affordable Air Compressor???
im sick of not being able to do stuff because i dont have an air compressor....id like to get one but need to keep it fairly cheap....i wanna use it for sanding and maybe spraying prime plus like regular impact wrench and stuff....anyways....anyone know where to get one like that for not that much?
Shifty101Easy is offline
Old 10-23-2006, 06:16 AM
THUMPIN455
THUMPIN455's Avatar
Default RE: Affordable Air Compressor???
Mine was around $1000 runs on 220v and will happily run the DA for hours on end.. Crank up the regulator and lugnuts are a breeze with the impact.
I am gonna guess that you dont need something like I have... Check around, a 3hp portable should work for what you want, just get a decent one.
THUMPIN455 is offline
Old 10-23-2006, 08:35 AM
jes72mustang
jes72mustang's Avatar
Check Sears and Home Depot, I got mine from Home Depot and it came with a bunch of air tools, like an impact wrench, air chisle, air ratchet and spray gun. I think it ran around $300-350.
jes72mustang is offline
Old 10-23-2006, 11:06 AM
Soaring
I ♥ Acer
Soaring's Avatar
For light duty work like you described, you don't need a woopty doo big name compressor. However, the bigger the tank, the longer it will pump before having to recycle. If you don't mind waiting between recycles, get about a 2 1/2 or 3 gallon one that pumps something like 120-130 PSI. Air guns require at least 70 psi. Check Ebay.
You can probably come up with one for a couple of skins. Or for one like this, you may get by real cheap. http://cgi.ebay.com/CAMPBELL-HAUSFEL...QQcmdZViewItem
Soaring is offline
Old 10-23-2006, 11:10 AM
randy78045
randy78045's Avatar
I got mine at home depot for a couple hundred dollars... big tank... cant remember how big though... seems like 40 gals... one thing you mentioned in your post was sanding.... if you forget sanding you can get by pretty cheap... sanders take large amounts of air... thats one thing i cannot do with mine...
randy78045 is offline
Old 10-23-2006, 12:16 PM
MC
MC's Avatar
Just Thought id boast, I wasnt gunna start a thread over this but check it.
I work for and insuation company for plants. Im the warehouse manager and been here for 3 months. They have beaders- crimpers- metal brakes-ect. They get rid of old tool all the time, I asked one of the project managers if he would sell me old grinders,drills anything he dont want anymore, There was an Husky 26gal 135psi Compressor( 377$ @ Home Depot) with a faulty regulator. He gave it to me and said If i fixed it i could have it. The part cost 24 dollars! Ill be priming Pale rider with that sucka.---KARMA---
MC is offline
Old 10-23-2006, 02:38 PM
67Stang68
67Stang68's Avatar
Save up a little extra money and get the most cfm you can afford, I picked mine up at Home Depot
its a 60gal 5hp 220v it can run 16.5 cfm at 135psi and its max psi is 175psi. It ran me like $850 it was
not the most expensive but was not the cheapest and it can run anything I need.
67Stang68 is offline
Old 10-23-2006, 03:14 PM
ebluekeys
ebluekeys's Avatar
since HVLP is the latest/greatest for painting, you want to get the highest CFM rating you can afford. Low end minimum for HVLP seems to be around 11 to 12 CFM. Naturally, more is better...
ebluekeys is offline
Lethaldosage423
10-19-2015 12:12 AM
Dokilar
15
10-16-2015 08:13 PM
fastbackford351
10-01-2015 12:24 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
Quick Reply: Affordable Air Compressor???
