Newbie ?
Newbie ?
My wife and I just bought our first classic mustang. It is a 66 coupe with a 289 auto. I have several questions to post but will start out one at a time. Coming from the distributer there is a wire that goes to the coil, ok. There is something round wrapped in electrical tape in the center of the wire. Could someone tell me what this might be, Thanks
RE: Newbie ?
ORIGINAL: Colorado_Mustang
Sounds like a splice. Definitely unwrap it and make sure it's assembled correctly.
RE: Newbie ?
Thunderize beat me to it. I was assuming it wasn't the coil wire...though I can't say that I haven't seen a spliced coil/spark plug wire.
ORIGINAL: randy78045
Well if its a splice, replace the plug wires... the coil wire will come with the set... [:-]
RE: Newbie ?
Does it look like someone spliced a wire, then soldered the two together and used heat shrink or tape? If it hooks up to the + side of the coil, it is the positive wire that should be going into your distributor. If it is spliced, then take that southern engineering stuff off and put a single wire from the plus (battery) side of your coil into the dizzy. If you still have points, consider the Pertronix electronic ignition upgrade for less than 70 bux.
[IMG]local://upfiles/10034/03DAD8713F1247F5827357DD2CD07184.jpg[/IMG]
