master cylinder replacement...
Old 10-24-2006, 12:50 AM
ADRIAN1
ADRIAN1's Avatar
Default master cylinder replacement...
so i took my car to the shop and they checked/found what the problem was with my brakes. Theres a leak in the master cylinder! therefor im buying a new one. i have never replaced a M/C and would like to know how difficult is it. the shop want to charge me $127 for labor. what do you guys think?...
ADRIAN1 is offline
Old 10-24-2006, 12:55 AM
Colorado_Mustang
Colorado_Mustang's Avatar
Default RE: master cylinder replacement...
Do you know how to bleed your brakes? If so, then this isn't a bad job. Two bolts hold on the cylinder, along with the brake lines.
Most people bench bleed the cylinder then install it and bleed the brakes. I never have bench bled my new master cylinders and have very solid brakes on all my cars.
But, $127 is kinda high for an hour's worth of work, but at least it does include all new fluid with freshly bled brakes (at least it should).
Colorado_Mustang is offline
Old 10-24-2006, 01:57 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
yeah if u know how to bleed brakes it will be well worth doing it yourself(a cool thing u can get at the auto parts store is called speed bleeders) they allow u to be able to bleed the brakes by yourself!
rmodel65 is offline
Old 10-24-2006, 02:14 PM
Grimm
Grimm's Avatar
I use the speed bleeder to flush new fluid into my lines once a year. $127.00 is way to much fo removing a couple of bolts. Do it yourself.
Grimm is offline
Old 10-24-2006, 04:35 PM
Soaring
I ♥ Acer
Soaring's Avatar
I suggest you bench bleed your new MC before putting it on. $127 is a ridiculous price for one of the easiest jobs ever.
Here's how to bench bleed the MC.
http://www.misterfixit.com/brakbld1.htm
Soaring is offline
GimpyHSHS
19
12-19-2023 01:12 PM
lincolnshibuya
07-05-2020 03:05 AM
b8checker
10-08-2015 12:55 PM
Dathan
10-05-2015 05:52 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: master cylinder replacement...
