How do I remove primer?
Old 10-25-2006, 02:36 AM
notoes68
notoes68's Avatar
Default How do I remove primer?
The guy I bought my mustang from let it sit outside with only primer on it and some rusted through. What is the best way to remaove the primer and rust?
notoes68 is offline
Old 10-25-2006, 02:41 AM
randy78045
randy78045's Avatar
Default RE: How do I remove primer?
Sanding, grinding, etc... the problem is not the primer... the problem is the rust, and the extent of it... pics would be helpful for those into body work...
randy78045 is offline
Old 10-25-2006, 02:42 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
80 grit sand paper and a dual action sander(or the fastest but messiest way air craft paint stripper)
rmodel65 is offline
Old 10-25-2006, 02:52 AM
baddog671
baddog671's Avatar
I find sanding to be extra work and extra cost. Buy the Aircraft stripper from walmart(brushable, not spray) and coat it on. Take a putty scraper or some flat blade object and simply scoop the paint off. Then hit it with a fine sanding to smooth the baremetal out.
And aircraft is no messier than all that dam sanding dust...
baddog671 is offline
Old 10-25-2006, 02:56 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
well depends on ur definition of messy but gooey paint that can burn ur hands andfumes that burn ur nose are messier to me than a little bit of dust
rmodel65 is offline
Old 10-25-2006, 03:22 AM
Shifty101Easy
Shifty101Easy's Avatar
i wish they made electric DA sanders.....
Shifty101Easy is offline
Old 10-25-2006, 01:16 PM
baddog671
baddog671's Avatar
ORIGINAL: rmodel65
I wear gloves and open my garage doors
Old 10-26-2006, 12:11 AM
stanging
stanging's Avatar
They do make electric orbital sanders, go to a Lowes or Home Depot. they have all sorts sanders. You can even get one that you can hook up to a shop vac. But the hose is sometimes a pain.
I don't know why people will prime a car and then drive it in all kinds of weather or leave it sitting outside. Primer does not prevent moisture from getting to the sheet metal, the paint does.
stanging is offline
Old 10-26-2006, 02:10 AM
baddog671
baddog671's Avatar
ORIGINAL: stanging
I just bought a new one today at Sears and Im very happy with it. Its a 3"x9" Craftsman sander, with 11 sheets, dustbag, and another attachemnt for 40 dineros. Papers is cheap as could be for that too.
And yes, primer is water-retentive. Actual paint is not. Mine actually sits inside my house and there are 2 dehumidifiers so I dont have to worry about it
Old 10-26-2006, 02:21 PM
heavensonfire
heavensonfire's Avatar
While on the subject of removing primer any ideas whats the best and safest way to get it off glass? I don't want to go at it with a knife or anything people who did my paint job we're just spectacular....and then they went out of business.
heavensonfire is offline
Quick Reply: How do I remove primer?
