Cowl Vent's Leaking!!
RE: Cowl Vent's Leaking!!
Yeah, I thought that I had rust problems before I found this site. After tearing out the carpet, I began stripping the rust off the floor, only to find out that was most of my floor on the driver's side.
you are ****ed... the same thing happened to me...... you have to dril out like 300 spot welds take the top of the cowl off and then make or buy patches then weld them in.... its a very invovled project
I read the tech articale about removing and replacing the cowls. What is the rear apron they are refering to? I know you have to pull the windshield, fenders, hood and the three hundred weld part. Then the article refers to removing the rear apron before removing the cowl. What is this part?
ORIGINAL: Grimm
Guess I'll find out when I get into it. I've seen the photos of the apron, but can't compare it til I get the fenders off. I may just order them anyway. The cowls are toast so that part will most likely be just as bad.
ORIGINAL: Grimm
bradleyb
11-27-2015 07:50 PM
