Last edit by: IB Advertising
Browse all: Brake Guides
- Ford Mustang V6 1994 to 2004 How to Replace Brake Fluid
Step by step instructions for do-it-yourself repairs
what brake fluid?..
what brake fluid?..
Ok im going to install my new master cylinder tomorrow morning. Im going to stop by Kragen since its around my block. what type of brake fluid do i need if i have all drum, manual brakes?...
RE: what brake fluid?..
I use any brand on sale at local Autozone as long as it is DOT 3 or DOT 4. Don't know if there is much of a difference in brands but sure someone here will have an answer. Be sure to get the large size and bleed those brakes a couple of times to get the air out.
Ya doesnt matter at all as long as its Dot 3 or 4. I usually grab the stp one...its cheap makes me feel better then the gallon for 3.49 although...about the same, but its the feeling Im putting more into it that counts right?
most brake manufactures only recommend brake fluid from a metal container(like factory ford fluid) but ive always used the regular stuff in the plastic(the reason for using the metal is it doesnt let moisture in like a plastic bottle)brake fluid absorbs moisture from the atomosphere
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
