running problem(please help)
Old 11-02-2006, 12:23 AM
stanger66
stanger66's Avatar
Default running problem(please help)
In the past 6 months or so, I was driving my car and it stopped running check the fuel filter it was clogged so I replaced it. Then it clogged up again in about 2 weeks so I fiqured I would drain the tank and I found about 3 inchs of slug in the bottom so I replaced the tank and sender (which the sock had fallen apart) and put new fuel in. When I went to drive it, it would run for about 2 miles and when I would sit at a light it would die if I didnt have it in neutral giving the gas. So replaced the fuel pump and the lines and the filter(again). I also replaced the plugs and wires. Went to drive it again and is still doing the same thing. So I replaced the distributor, cap, and rotor thinking it was spark related issue. Went to drive it again same thing. I replaced the carb about 1 1/2 yrs ago, do I have to replace it again or what do you think it could be. I loosing patience with it. I have 200cid 1 barrel junk carb.
One of my friends said I should get a carb from a 72 250cid 1 barrel but I would have to jerry rig it to make it work. Like ream out the spacer plate so the butterfly can move freely. I just dont want to do that(too much work).
Should I get another carb or rebuild it.
stanger66 is offline
Old 11-02-2006, 12:29 AM
mustanglover66
mustanglover66's Avatar
Default RE: running problem(please help)
I would buy a rebuilt or rebuid it once you start rigging thing tne next thing you know your a shadetree mech.
mustanglover66 is offline
Old 11-02-2006, 12:32 AM
ideal_mustangs
ideal_mustangs's Avatar
Do a rebuild of the carb. It sounds like you've probably got some junk in it if your tank and lines were that dirty.
ideal_mustangs is offline
Old 11-02-2006, 01:15 AM
stanger66
stanger66's Avatar
ORIGINAL: mustanglover66
Im not a shade tree tech. My forta is the fuel injection age. I never really have dealt when carb systems when I was a master tech when working on cars. That was mainly before my time. Carbs are all new to me. If I had carb issues I used to take my friend that used work on carb systems but he is no longer around since got killed in a car accident.
Old 11-02-2006, 12:37 PM
Bulldog66
Bulldog66's Avatar
If you're a master tech then rebuilding a carb should be cake. Just get a clean working surface, compressed air and a bucket of parts cleaner. It goes together just like it came apart.
You should be able to do this blindfolded, seriously.
Bulldog66 is offline
Old 11-02-2006, 02:16 PM
Brandontyler65
I ♥ Acer
Brandontyler65's Avatar
hmm i would rebuild the carb i have also heard of people using webber carbs in place of the stock one and they make an adapter plate
Brandontyler65 is offline
Old 11-02-2006, 02:59 PM
Soaring
I ♥ Acer
Soaring's Avatar
If it is a Motorcraft 1100, I would get a rebuilt one from pony carbs. They say that carb had problems right out of the factory, buy they alter the carb somehow to make it work well. Give them a shout. http://www.ponycarbs.com
Soaring is offline
djbigskrilla
09-20-2022 01:04 AM
KinneyD
01-09-2016 05:33 PM
Luclin999
09-07-2015 11:33 PM
jjwinel78
08-17-2015 03:34 PM
Pain.
08-07-2015 10:48 PM
Quick Reply: running problem(please help)
