Best way to hook up Electric Choke
Old 11-02-2006, 01:35 AM
4reboy
4reboy's Avatar
Default Best way to hook up Electric Choke
What is the best way to hook up an electric choke? I did a search but didn't find anything that useful. I just know that I need to put it on a 12V source that only has current when the car is actually running. Where is the best place to do this?
I was thinking the coil, but then I read that is only roughly 9V when running. What are other options that are effective and look aesthetically pleasing?
Here's info on my setup - 351w, p/s, no AC, Edelbrok 650cfm carb. What are my options for the choke setup? We are almost to the point to start the car, just a few more things to check off the list.
4reboy is offline
Old 11-02-2006, 01:38 AM
green_blurr
green_blurr's Avatar
Default RE: Best way to hook up Electric Choke
You can hook it up to your alternator
[IMG]local://upfiles/43944/677ED1487091442594B6A4156D53360F.jpg[/IMG]
green_blurr is offline
Old 11-02-2006, 02:13 AM
Brandontyler65
I ♥ Acer
Brandontyler65's Avatar
i hook mine up ti the I on the ignition soledoid
Brandontyler65 is offline
Old 11-02-2006, 03:39 AM
DGA
DGA's Avatar
Personally I wouldn't hook it up in the first place. Assuming that the hot air line from the exhaust heater is in place.
However the proper source is the stator terminal of the alternator.
DGA is offline
Old 11-02-2006, 02:19 PM
Brandontyler65
I ♥ Acer
i know
Old 11-02-2006, 10:36 PM
4reboy
4reboy's Avatar
Thanks guys.
Where should I hook the heater blower motor up to? We know where the ground goes but not sure on the power...when we got the car it was disconnected with the wire cut off.
4reboy is offline
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
88 orangepeel notch
10-05-2015 09:03 AM
DtRockstar1
Mustang Videos
09-27-2015 07:46 PM
mrappe
09-26-2015 10:16 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: Best way to hook up Electric Choke
