Putting a T-5 behind a Ford 200???
What bellhousing, clutch, and flywheel do i need to do this? Car has a c-4 and I have everything for the V8 and maunal swap, just want to build the 302 before I put it in, so I want to cruise arround with the 200 while I build it.
RE: Putting a T-5 behind a Ford 200???
well in order to put it on ur gonna need an adapter plate to adapt it to a manual bell that will fit the 200 and then all of the other conversion stuff to get the T-5 in the car
moder driveline sells adapters
I guess anything is possible. You are going to need the correct bellhousing and clutch set-up. See if this helps. http://www.fordmuscle.com/archives/2000/09/t5swap/
the car currently is a 66 coupe with a c4 and a 200. i'm converting it to a 302 with a t-5. right now the manual pedals are in it, and the c4 is leaking bad. so instead of fixing the c4 to get registered, i figured why not put the t-5 in now, behind the 200, then build my 302 up and drop it in later.
and yes i know the differences for just dropping a v8 in, thats why i allread put an 8 inch rear in the car and upgraded the suspension with global west uppers and grab a traks coils and leafs with new lower control arms and also converted the car to disk brakes.
i know a guy down here that did the same swap i want to do, t-5 behind a 200, but i haven't seen him since july, so i was hoping to pick everyones brain here
Here is a thread I did a long time ago
https://mustangforums.com/m_599071/tm.htm
here is the link to modern driveline. Notice it's not too hard to figure out, and a google search on Modern Driveline would bring it right up for you.
www.moderndriveline.com
Also for great information on pretty much anything dealing with the 6 cylinder Ford try this
http://fordsix.com
Lastly there is a bit more information on the web site in my signature. Look at the page for installing the T5z.
Good luck,
http://fordsix.com
Good luck,
