rear meats
rear meats
is there anyway i could put some big *** drag like tires on my rear tires? i think i have 7s now and they are wimpy wimpy wimpy. I really dont wanna tub the trunk and if thats what it comes to screw it i wont do it. its not like im putting down alot of power or anything (YET!) but i love the look. an wider on my tires and they rub like crazy, trust me i tride a size wider. are there any alternatives to tubbing the trunk without having the wheels sicking out of the fenders? thanks guys.
RE: rear meats
With a lot of careful measurements, and a lateral link (PHB or Watt's) you can run up to a 10" wide section width tire inside the fender wells. That will require rolling the fenders, which is a real tough job, even with the proper tool. You would be much safer with a 9" section width tire. If you pick the right tire and rim, that will give you a solid 8" wide patch on the ground. That is close to double what you have now. Then get some nice sticky tires and you're golden.
I think part of the problem you are facing right now is due to the back space of your rims. The look a little shallow...not that there's anything wrong with that...Hal
Good luck,
Good luck,
