carbureted pcv system
RE: carbureted pvc system
I don't think the oil leak is related. That sounds like an intake gasket problem. Don't use the cork gaskets on the front and back use only RTV. Does he black hose go to the Booster?
its been driving my mad , lol, not trying to say ur wrong , but how would the the gasket efeck it comming from around the bolt s? and dose the VJR intake have those nipples??
Don't know about the Victor Jr. You are talking about he intake bolts right, not the valve cover bolts? If oil is coming from around the intake bolts it would have to be the intake gaskets.
There definately should be a vacuum nipple on that Holley somewhere. If you do not have another vacuum source on the intake, you can drill and tap one into the plenum area. As for the oil coming out arond the intake bolts I used to use a little RTV around the head area. Small block Fords do tend to seep oil around these bolts.
bradleyb
11-27-2015 07:50 PM
breaking
10-02-2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
