Check out my Transmission
Yesterday I drained the fluid and took off the pan and was suprised to see how clean it was in there! My dad and I are pretty much possitive it has been worked on fairly recently. What do you all think? BTW its an FMX transmission
How long ago do you think my tranny was worked on?
RE: Check out my Transmission
Looks good. Are the dark spots on the filter gunk or just fluid?
While your working on your car, add an external tranny filter. You'll greatly improve the life of your tranny. Summit Racing sells one from Trans Dapt that I've used on a couple vehicles.
Thanks for the input guys. I'll look into that external filter. And the dark spots, I'd assume would be some sort of gunk, but the filter will be changed anyway.
In the days before quality engine oil was available many knowledgable guys would add a quart or two of Type A (Not thpe F which had 'improved' friction characteristics) in place of Engine Oil with their oil change
No need to now--The common brands of SE oils are much better all around.
