rear gear
RE: rear gear
you can find out rather easily. Ther eis a tag on it that will tell you, unless its been removed or changed.
There is another tag on the drivers door that should have what the car was originally built with.
Also you can lift the rear of the car, put it on jackstands, place the shifter in neutral. Now you can rotate the wheel so the valve stem goes around one complete revolution. Count how many times the driveshaft goes around.
if the driveshaft spins 3 times, its 3.00:1, if it spins a bit more than 4 times, its a 4.10 or more gear. If it doesnt quite spin 3 times then its under 3.. you can sorta guess at the ratio from how far it spins past each whole number.
If you car is stock and unchanged, it will usually have a 2.70 or a 3.00 rear end in it.
Luke9222
10-22-2015 11:55 PM
musnicki
09-23-2015 07:11 AM
09-01-2015 08:16 PM
