Coil springs upsidedown?
RE: Coil springs upsidedown?
The spring saddle has a little tip on the back side that the open end of the coil will be near too when the coil is installed properly.
Basically, the coil goes in open side down, flat side up, and rotated around so where the coil stops is in the back closest to the sheetmetal side of the tower.
ORIGINAL: sixtysix
I have a 66 with stock springs-do you think if I upgrade to 620 springs it will stop the tire rub I am getting-I put 215 15 x7 up front and I get some rub when I hit some bumps...Thanks scott
While you have it apart, lower the arm with the shelby drop, then get it aligned to the shelby specs.
