rear axle question
rear axle question
I have had a suspension knock for a while, could not find out what it was until to day, on the rear axle drivers side half way down there is a part about breather which is abouthigh 1/5-2" , this was hitting the exhaust on compression, **** shocks, it is now loose and can't seem to tighten it down. Is this going to course a problem? how can I make it lower thus avioding the exhaust. Cheers
[IMG]local://upfiles/40810/245DD2FB8BAC425482896A0919BB7D1C.jpg[/IMG]
[IMG]local://upfiles/40810/5F122AB9E09C460E9F8D79940B20723D.jpg[/IMG]
RE: rear axle question
The part you are talking about is the axle vent tube. It does 2 things on standard mustang.
1. It of course vents the axle and there should be a length of tube connected to it that goes up to a higher spot on the car.
2. The vent nipple itself threads in the axle tube, and holds the rear brake line distribution block. There is ussually a soft brake line connected to it from the transmission tunnel and then 2 hard lines to the left and right brakes.
so i might have broken the threads in the axle to which the vent nipple goes in but that not a big problem, I does seem higher than it needs to be above the rear axle but i take it is level with the axle fill point
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
09-01-2015 08:16 PM
