fuel pressure?
fuel pressure?
i have a edlebrock carb and when i turn the car off the carb fills up with gas would this be fuel pressure problem? then if i open it up and re adjust the float it will work but f i wait a few days it starts acting up again ? any advice
THANK YOU
THANK YOU
RE: fuel pressure?
Well recommended fuel pressure is between 5-7psi, so not very much at all. And when you say its filling up with gas, do you mean you can see gas pouring out of the venturi's when the car isnt running? The float bowls should be full when the vehicle isnt running anyway, they shouldnt go dry once you shut the car off.
-P.
-P.
mrappe
09-26-2015 10:16 AM
