want to customize my bumpers
I want to shave the bolt heads off the bumpers and have them set closer to the body ,
Anyone know of a good tech article on the net or some advise? Thanks
RE: want to customize my bumpers
probably want to go fiberglass if ur gonna go that route could get the glass bumper section it and bond it on with a fusor panel adhesive thats what im gonna do with my rear bumper
im not gonna section mine but im gonna get the glass rear bumper for a minimalist chrome look just the grille surround, and the window area will get the stainless trim and maybe side emblems
Dont get ur panties in a bunch Soaring
If any one saw the carcraft issue there this orange camaro with the bumper bolts shaved off then it';s painted grey. i still want mine chrome but cant figure it out,, also i think Foose did it a couple times to his Overhauls. I think that you most likely wouldnt notice right off then after you had a double take youd be like,....wait a minute, that looks different. Just no bolt heads is all im talkin about, I think it would look cleaner and sleaker and keeping the true lines of the car. Now i dont know about fiberglass , I'd have to see it first --but it's thinkin Out of the Box. Good luck bro,--
"I'm Just Sayin"
"I'm Just Sayin"
I saw that camaro in Hot Rod. It was a hot chick that did it too! Just cut the heads off the old bolts and weld them it. Then smooth the welds and either have it rechromed or like the camaro did just paint it to look like brushed steel.
David Stacey did it on an issue of Trucks, didn't look too hard, just welding and grinding. You would of course need to get it re chromed, or painted. As stated the look would be suttle, but those who notice would appreciate the work.
These guys talk about the plating process, they don't want you to grind down the front after you weld on the bolt.
http://www.advancedplating.com/resto...mper_resto.htm
If you know how to weld this is an easy project, the only real cost is the re-chrome
Keith
Keith
jwog666
12-27-2021 08:09 PM
