need help hooking this up
how do i hook up this alternator...looks like the new one only takes one wire where as the old one takes 3?
[IMG]local://upfiles/18218/AD8AF76AD10F46B7B3E123DA9350EB66.jpg[/IMG]
[IMG]local://upfiles/18218/831B901DA80D4EAFB1F0174E6A4C26E0.jpg[/IMG]
[IMG]local://upfiles/18218/658BB69C1B9543519E0F018F4AB1F109.jpg[/IMG]
RE: need help hooking this up
Run a 10 gauge wire to the positive side of the selonoid.
Tape up the rest of the wires that used to be plugged into the Alt (or remove).
remove the volatage regulator and tape up those wires too.
At least, that's how I would do it.
Since you say "1 wire" that means you have an internally regulated late model alternator...right?
No. The extra wires on the externally regulated alternator are for the regulator (they control whether the alternator is 'on' or not to control the output).
For the single wire, I run a 2 gauge wire with a breaker in series.
ORIGINAL: eZ
dont some of the other wires run my lights and such?
Late model 3g alternator installation:
http://www.mustangmonthly.com/howto/26599/
1 wire, internally regulated alternator installation:
Per my instructions above, you can go larger gauge if you chose to. I chose 10 gauge for the 100 amp unit I run.
Your lights are powered though the harness elsewhere, they are not directly connected to the output of the alternator.
Just being nit-picky (I'm an engineer...what would you expect), but wire can only handle so much current. A decent online reference is here.
ORIGINAL: dodgestang
ORIGINAL: Colorado_Mustang
ORIGINAL: Soaring
So, what is the maximum gauge wire for a one wire 100 amp alternator Mike?
Not to skirt your question Soaring, but I'd have to dust off my old books to determine the exact answer!
Also, to add to Dodgestang's post about a "light load in the car": Just because a 100 amp alternator is installed doesn't mean its always sending 100 amps through that cable. Really depends on the amp (current) draw/demand.
Hope that didn't muddy up the understanding for anyone.
