Just blew up a muffler!..need some timing help
Old 12-06-2006, 09:43 PM
stevannadj
stevannadj's Avatar
Default Just blew up a muffler!..need some timing help
ok so its a 351C 2V, holley 2bbl carb, stock distributor with pertonix conversion. So I was in the process of retiming my engine and when I went to crank it...BOOM. Bye bye driver side muffler. How did this happen? Am I 180 degrees off? Anyone that can tell me a step by step process on retiming this thing will be greatly appreciated. Ive been bring the #1 cylinder to TDC via looking at the balancer and pointer. Ive tried this several times and no luck. Please someone shed some light on this for me. Thanks
stevannadj is offline
Old 12-06-2006, 09:52 PM
badazz68stang
badazz68stang's Avatar
Default RE: Just blew up a muffler!..need some timing help
make sure your hitting TDC on the right stroke so you wont be out 180. This caused your muffler to blow up or fall off or what
badazz68stang is offline
Old 12-07-2006, 12:07 AM
69mach1377
69mach1377's Avatar
You might be out 180*. Pull the #1 plug and feel the pressure build on your finger that is plugging the hole as you manually crank the engine. Sort of like playing twister with your stang. Now your at TDC for reals.
69mach1377 is offline
Old 12-07-2006, 12:11 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
if u have the stock balancer the outer ting might have slipped making the mark wrong
rmodel65 is offline
Old 12-12-2006, 03:33 PM
hellas85stang
hellas85stang's Avatar
put a screw driver carefulllllllllll in plug hole till comes allway up and just b4 moves down thats about tdc//look at where ya distributer rotor points to and make ya spark plug#1 start there...double check firing order....i believe 351c are same as 302 and have a reverse firing order...in counter clock direction..make sure by crankin motor and seein which way ya rotor moves...
hellas85stang is offline
Old 12-12-2006, 05:35 PM
Soaring
I ♥ Acer
Soaring's Avatar
A neat way to find TDC on #1 is to stuff a rag in the spark plug hole, and turn the engine over until the rag "pops" out. Then put a screwdriver in the hole, and you will feel the piston at the top of the stroke.
Soaring is offline
Old 12-12-2006, 05:40 PM
Soaring
I ♥ Acer
Soaring's Avatar
ORIGINAL: hellas85stang
NO! The 302 and the 351 have entirely a different firing order. The 351 is 13726548
Soaring is offline
Old 12-12-2006, 07:33 PM
THUMPIN455
THUMPIN455's Avatar
I thought I replied to this... strange.
Glen is right about the firing order.
Was it a different thread or just a double post... my head hurts. I am gonna go weld some more.
THUMPIN455 is offline
Old 12-13-2006, 02:01 AM
69mach1377
69mach1377's Avatar
Double post by a newbie...
Old 12-13-2006, 02:16 AM
ford65stang
ford65stang's Avatar
the muffler blew up or just a back fire ?
ford65stang is offline
2007CalSpec
12-13-2020 11:42 AM
FivePointToTheOh
10-02-2015 04:09 PM
Webster454
09-07-2015 04:59 AM
Quick Reply: Just blew up a muffler!..need some timing help
