Alt update
Old 12-07-2006, 10:33 PM
Pkohn1
Pkohn1's Avatar
Default Alt update
I have a 1970 mustang I would like to update from an external voltage reg to an internal. Could someone let me know how to convert to a one wire Alt. and how do I handle the plug at the voltage regular. Do you connect wires together? Any help would be appreciated, thanks in advance!
Pkohn1 is offline
Old 12-07-2006, 11:27 PM
dodgestang
dodgestang's Avatar
Default RE: Alt update
The answer to your question is on the first page of post for this forum. "need help hooking this up"
dodgestang is offline
Old 12-10-2006, 02:14 AM
Pkohn1
Pkohn1's Avatar
Thanks for pointing me to the information. I have a 130 amp 3G alternator. It has two additional plugs in it. Do I just run the wire as indicated in the form and leave everything else alone or do the other plugs have any value? Thanks again for the help or should I get an alternator from a different application?
Thanks
Pete
Pkohn1 is offline
Old 12-10-2006, 02:17 AM
Colorado_Mustang
Colorado_Mustang's Avatar
Do you have the instructions?
Colorado_Mustang is offline
Old 12-10-2006, 12:05 PM
dodgestang
dodgestang's Avatar
Wiring in a 3g altenator is a little different that wiring in a one wire alternator in a classic mustang, but if you follow the directions on wiring the 3g linked in the other post I point to you will be fine. I haven't personally wired a 3g so I am not much help in the 'experienced' an installation before other than I understand how daunting it can sometimes feel cutting and splicing on your wiring harness when you aren't exactly sure what it is that is being done
Old 12-10-2006, 04:53 PM
Pkohn1
Pkohn1's Avatar
I have the instructions from the 3g alternator box.
Pkohn1 is offline
EZFEED
05-05-2016 08:54 PM
Kenta08
09-02-2015 10:33 AM
67LimeCoupe
09-02-2015 08:02 AM
movielover40
08-27-2015 10:13 PM
Quick Reply: Alt update
