AFR Heads
AFR Heads
Hey all, what do you think of the AFR 165 Heads?
I have been trying to configure my engine and am looking at AFR heads, Edelbrock performer intake, 600 cfm carb,lifters and cam, and either tri Y headers, or hooker comp, not sure. and a shift kit for the C4.
Opinions/experience with AFR?
Thanks all
Thanks all
RE: AFR Heads
well if you want great throttle responce,good low to mid-range hp and not too concern about higher end hp then the 165 is just the head for you used with a typoon daul plane intake and that 600 holley and a small cam you have a nice quick car that can idle in traffic and not heat up..in using the cam something around 480 lift would be about as far as I would go with making sure more lift is on the exhaust side and keeping your .050 duration in the 218-220 range.. and nice 2000 rpm stall would help get thing moving quicker as would a nice set of 3.55's and a big transmission cooler
