Gas odor
RE: Gas odor
I checked the tank, it appears that there are not any pinholes. From what I can tell, the tank is not very old. Stange thing thing is the tank looks fairly new, but all the lines seem like they are original. I would think that if someone went to all the trouble to switch out the tank they would have also tackled the lines?
RE: Gas odor
my wifes stang had new lines and holes the size of quarters in the top of the tank!! the gas was orange in the clear filter at the carb.....the PO couldn't understand why it ran so crappy? go figure...............[sm=bangbang.gif]
RE: Gas odor
I think my problem may be my line from the fuel pump to the carb. I had not noticed until this problem that at some point someone had done a sloppy repair to the original steel line. They had taken the steel line from the pump, cut it and attached a rubber hose that goes into a fuel filter. Then from the fuel filter there is a 1 inch piece of braided line to the carb. All held together with cheap clamps.
Needless to say, I'll be ordering a new stainless line from NPD today.
Matt's 95 Stang
10-05-2015 07:16 AM
