69 Master Cylinder Brake Help ASAP plz
Old 12-11-2006, 05:38 PM
mlitz
mlitz's Avatar
Default RE: 69 Master Cylinder Brake Help ASAP plz
my sugestion would be to pull the master cylider off and bench bleed it[&:]
mlitz is offline
Old 12-12-2006, 12:34 AM
Colorado_Mustang
Colorado_Mustang's Avatar
It does take longer if you don't bench bleed. Will the brake stay hard after you pump it up? If so, you just have more bleeding to go.
ORIGINAL: MidNite27
We are properley bleeding the brakes, the fluid is clear now, we dont see much bubbles. The pedal goes to the floor when the car is running and u have to pump it up to get brakes, which means u are compressing the air in the lines resulting in braking power. So i guess it just takes ALOT of brake bleeding if you dont bench bleed the master when u reinstall it. Anyone else confirm this?
Colorado_Mustang is offline
Old 12-12-2006, 04:46 AM
MidNite27
MidNite27's Avatar
Yeah it stays hard after i pump it up. Lol i'm tired of, Ok DOWN, UP, DOWN, UP, DOWN, UP etc. etc. And i can only do this when i have a freind to help out lol. Will Bench Bleeding the Cylinder now fix it? I mean isnt all that air that i didnt purge in the cylinder in the beggining already pushed into the lines?
MidNite27 is offline
lincolnshibuya
07-05-2020 03:05 AM
b8checker
10-08-2015 12:55 PM
Dathan
10-05-2015 05:52 AM
b8checker
09-30-2015 07:11 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: 69 Master Cylinder Brake Help ASAP plz
