What Wheel Size recommened for a 67 Coupe
Hey there party people,
I am getting ready to buy my front wheels and tire set for my 67 Coupe. I am currently running on the stock (14x6 or 14x5 i believe) wheel/hubcap combo and have decided to step up to the Cragar Soft 8's for the time being. I already have a set of 15x8 for the rear and was planning on mounting some Nitto 555r 275/60/r15 (recomended by a Nitto rep at the LA Autoshow). Does anyone know if the 15x8 would fit on the front? Or should I go with the smaller 15x7? Cragar doesn't make the style rim I am using in a 15x6, I would have to special order that if I wanted it. Also, any suggestions for tire sizes? I am going with drag radials in the rear and not sure what size I should go with. The front will most likely be Nitto 450's, nothing special, just a standard driving wheel up there.
Any suggestions and help will be appreciated. Thanks in advance.
-Edgar
-Edgar
RE: What Wheel Size recommened for a 67 Coupe
ORIGINAL: restomod67
I'm running 15x8 rear and 15x7 front. It's a really nice setup. Not sure if you can fit the 15x8 on the front though.
See if this chart helps.
http://www.dodgestang.com/mustang.htm
