New Heater Core, New Problems.
This is somthing that really sucks....espcially since i live in the south... I just got my heater core replaced this week in order to prepare for the winter (i drove last winter without a heater in my car), and when i picked up my car today the heater was working fine...only problem...(that i didnt figure out until i was well off on the road) was that the heater doesnt turn off!!!
I had a chat with a buddy of mine about it and he says that i need to get the heater switch turned off...which requires more mechanical labor to get underneath and make those switches....anywho, until i can get my car back to my mechanic...ima get to drive around in an A/Cless car, along with blasting heat...how fun.
RE: New Heater Core, New Problems.
there is a water diverter valve, its called a heater control valve, mounted on the firewall at the passenger side in the engine compartment. Over time, they get corroded inside and wind up sticking, usually in the open position, allowing hot water to continuously flow to your core, even when you arent asking for heat. It is vacuum operated, so either your vacuum lines are leaking or the valve itself is no good. Oreilly Auto Parts had a Jap replacement for my 68, plastic, but it does the job for about 10 bucks.
yea i know what youre talking about...so all i need to do to fix it is get a new control valve?
edit**
I found a Heater Control Valve here :
http://www.restoremustangs.com/index...40&PID=1311371
for $50, and thats w/ AC
But i checked Oreilly parts and found a Heater valve selling for $10...whats the difference?
edit**
ORIGINAL: ivanr77
edit**
edit**
The one I bought from Oriellys looks exactly like the original, except its plastic. . I used epoxy to mount it, and it looks, and works just fine. Saved 40.00 too!
Seanam
10-04-2015 10:15 AM
zanemoseley
09-06-2015 12:58 PM
Calizic
08-28-2015 01:46 PM
