Flickering Headlights
Old 12-17-2006, 06:28 AM
ford65stang
ford65stang's Avatar
Default RE: Flickering Headlights
hmmm does it do it on high beams too or just low ? I would check all connections and the floor high / low beam switch......before i would replace the headlight switch...see if the rear lights flicker too....have someone follow you. and check to see if any other lights are flickering.....
then check the connections at the headlight switch. make sure all the wires are fully pushed into the connector all the way....i had that problem on my starter wire on another car....
ford65stang is offline
Old 12-17-2006, 02:54 PM
Colorado_Mustang
Colorado_Mustang's Avatar
You probably have a mechanical VR that's worn out. If it was the circuit breaker in the headlight switch the lights would go off and on, not flicker.
Colorado_Mustang is offline
Old 12-17-2006, 06:37 PM
bodyputtyless
bodyputtyless's Avatar
I have the same thing happening to my headlights. I notice that at some rpms the flickering stops. In my case I believe it has something to do with the petronix electronic ignition that I installed several years ago. All my grounds are good, and like I said, the flickering stops at certain rpms. Its more of a pulsating factor. The lights never go out they just have a noticeable flciker.
bodyputtyless is offline
Old 12-17-2006, 06:43 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
ORIGINAL: bodyputtyless
if they are pulsing u need to upgrade to an electronic voltage regulator if u have the original one just put it in the box to save it for shows etc
rmodel65 is offline
Old 12-17-2006, 08:39 PM
ford65stang
+1
Old 12-17-2006, 11:32 PM
Brandontyler65
I ♥ Acer
Brandontyler65's Avatar
i had that problem i traced it back to my dimmer not making good conection
Brandontyler65 is offline
Old 12-17-2006, 11:39 PM
LCC
LCC's Avatar
X2
LCC is offline
Old 12-17-2006, 11:54 PM
Brandontyler65
I ♥ Acer
but i also like the solid state regulators i made one for m dash and i got one for my alternator they are since you don't have to set them
Old 12-18-2006, 12:10 AM
6mustang6
6mustang6's Avatar
i was going to say check the floor dimmer switch.
6mustang6 is offline
Old 12-18-2006, 12:14 AM
Soaring
I ♥ Acer
Soaring's Avatar
It's a grounding problem where you have rust.....
Soaring is offline
Quick Reply: Flickering Headlights
