Distribution Block Drum Brakes
Old 12-19-2006, 12:22 AM
palerider
palerider's Avatar
Default Distribution Block Drum Brakes
Put new stainless prebent brake lines on - had a slight leak at distribution block - when tightening cracked one of the ports. Need to locate "A" in attached. According to monthly mustang these part is for 67 thru 69 drum - since I have a 70 must fit that also. Check all catalogs and can't seem to find one except CJ Pony they said it's been on back order for awhile - Sine I have prebent stainless lines need to get something so that I don't have to mess with lines too much - any suggestions would be appreciated. Dallas Mustang has the attached one but not sure since it has ports on each side.
palerider is offline
Old 12-19-2006, 01:55 AM
noroof66
noroof66's Avatar
Default RE: Distribution Block Drum Brakes
I use mustangsunlimited a lot. They seem to have a little better inventory than CJ.
noroof66 is offline
Old 12-19-2006, 02:46 AM
Colorado_Mustang
Colorado_Mustang's Avatar
I've got the old one off my '71. The mounting bolts (2) are on 7/8" centers if that helps.
Lemme know if that'll work or not.
Colorado_Mustang is offline
Old 12-19-2006, 02:57 AM
Brandontyler65
I ♥ Acer
Brandontyler65's Avatar
have you tried your local parts store
Brandontyler65 is offline
Old 12-19-2006, 09:12 AM
palerider
palerider's Avatar
Thanks Colarado - May take you up on that - I'm checking with JJs Mustang for a used one they are suppose to let me know today. Local guys don't carryit. You'd think that this is a common part - must not be too many people snapping them when changing lines :
GimpyHSHS
19
12-19-2023 01:12 PM
Matt's 95 Stang
10-05-2015 07:16 AM
mustangheaven
09-29-2015 11:00 AM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Distribution Block Drum Brakes
