i forgot what a complete engine looks like!
RE: i forgot what a complete engine looks like!
ORIGINAL: rmodel65
make sure its not hittin on the header grounding out like mine[&:] what kinda starter problems u having?
So now that we know the starter works it might be a grounding issue. I have the battery lead grounding to the block, but my dad and I are thinking we should attach it to the starter bolt. If this doesn't work, I'm going to take the starter back and have them replace it and hope for the best!
ORIGINAL: rmodel65
sound like a dead battery
sometimes it still wont work take it to the parts house for a free test they usually have an hour or 2 wait on getting the results
ive had cars that wouldnt jump off with a car or a charger set on the high setting
ORIGINAL: rmodel65
Thanks for all your input.
Sounds like you don't have a ground strap between your engine and chassis. Without it, you will have all kinds of electrical gremlins...just like the ones you're experiencing.
ORIGINAL: 4reboy
Oh I see. Ok well if changing the ground doesn't solve my issue then I will take a battery out of a working car and try it Then if it still doesn't work....hmmm
ORIGINAL: rmodel65
X2 on the ground strap to the chassis. On my '85, the bolt came loose on the body and chasing that down was an absolute nightmare. As for the starter, stay away from that remanufactured Kragen junk. BTDT. It truly is a game of chance when you go that route. I'd spend the extra money on a new, quality starter. Also, just to rule out your battery, you could make sure the terminals are real clean and make good contact. Also, instead of the 100-amp start, try jumper cables from another vehicle.
thread jackers! but its fine
thumpin, sorry, but i LOVE these valve covers. i originally wanted some that said
Powered by Ford but i like these more. i have some chrome covers that are just chrome that i got for free.
Fuzzy, longtube super comp hookers, H pipe with some mags or flows 40
ok, i Was going to work on my engine tonight, but i went and had a small celebration, see other thread
