68 Strut Rods on 67?
Old 01-01-2007, 05:11 PM
baddog671
baddog671's Avatar
Default 68 Strut Rods on 67?
Before I place a bid on strut rods, I'd like to make sure the 68 assembly will bolt up toa 67 body. Thanks all!
Nicolas
baddog671 is offline
Old 01-01-2007, 05:19 PM
mayh3m
mayh3m's Avatar
Default RE: 68 Strut Rods on 67?
identical
mayh3m is offline
Old 01-01-2007, 05:29 PM
baddog671
baddog671's Avatar
Great!
While Im at it, I just had a little question out of curiousity. Is there any purpose to that piece of the rod that bends straight up? It's right after the bolts where it bolts to the LCA I believe. Heres a small picture for you to see...
67t5ponycoupe
67t5ponycoupe's Avatar
Not true, the 67 and 68 strut rods are different.
67t5ponycoupe is offline
Old 01-01-2007, 05:30 PM
67t5ponycoupe
The bent up piece is a steering stop. The 67 has the same rods as a 65-6.
Old 01-01-2007, 05:48 PM
2bav8
2bav8's Avatar
You can use 68 strut rods on a '67 but you will also need '68 lower control arms.
2bav8 is offline
Old 01-01-2007, 06:01 PM
paddy187
paddy187's Avatar
not identical for sure, i agree with 67t5 and 2bav8
paddy187 is offline
Old 01-01-2007, 06:34 PM
baddog671
baddog671's Avatar
Ok, thank you all! Guess I wont be bidding on that auction
Old 01-01-2007, 06:37 PM
deadcarnahans
deadcarnahans's Avatar
I'm stripping down a 67 FB if you are interested in some used parts....
deadcarnahans is offline
Old 01-01-2007, 09:32 PM
THUMPIN455
THUMPIN455's Avatar
I could use some 67 strut rods... Since the Cougar had a bushing on the control arm end and nobody makes that rubber bushing. It would be nice to not have to resort to a 68 LCA..
THUMPIN455 is offline
baddog671
07-26-2016 01:20 PM
jrrhd73must
10-02-2015 09:17 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
UrS4
09-30-2015 10:13 AM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: 68 Strut Rods on 67?
