carpet underlayment for '69...
#21
RE: carpet underlayment for '69...
That's a convertible part. It adds some support across the floorpan. The only problem I can think of with using it is you may need convertible carpet. That said, if those were available when I did my floors, I would have bought that instead of the two separates.
#22
The seat pedestal that goes all the way across is for a convertible. It won't fit a coupe or fastback without modification because the convertible rocker panels are different. I thought about that for my 70 fastback, but just decided to fix the ones I had.
#23
ORIGINAL: JamesW
No heat gun, just need a halfway warm place. I did mine in August in Texas and it just pressed into place with my hand.
If I were going to do a complete 69, I'd buy 100 ft. to coverfrom the bottom of the front cowl to the rear bumper. You'd have a little extra to do behind the sail panels. Probably 15 ft wason myfirewall, so you may not need that much. If you get too much, you can always use it inside the doors.
