68 Mustang Engine Pics
After seeing 67 Sally's post regarding the 67 289 engine bay and hose routing, i was wondering if the guys and gals out there with 68 Mustangs could post pics of their engines. In particular, the heater hose routing and vacuum hose routing for 289s with AC.My shop manual for the 68 shows a different configuration for the heater core at the fire wall as well as not showing the location of the control valve at all. My 68 also looks significantly different from the pics of the 67s in 67Sally's post. The feed and return hoses for the heater coreend atthe fire wallside by side, not one over the other. I also want to make sure that I've got it hooked up with the water control valve on the correct hose and mounted correctly on the firewall.
RE: 68 Mustang Engine Pics
ORIGINAL: sxs191
The 302 replaced the 289 in January of '68'.
OMG....so sinceI'm missing the tag that was under the coil (and all other forms of ID save the state-issued one since it was stolen at one time) I could be driving a 289?? Is that casting number on the block the only way to tell for sure ?
You could always use a what's it called micrometer and determine it that way, or check you engines numbers... but my intake is from a 289, and from what I understand it was quite common to have 289 parts all over a 302
