1970 mach 1 power steering
Old 03-11-2003, 10:03 PM
ken testa
ken testa's Avatar
Default 1970 mach 1 power steering
I am replacing the incorrect power steering hoses on my 1970 Mach 1 428CJ with factory correct reproduction hoses. I also purchased the hose bracket which holds the two power steering hoses and is mounted on the lower front suspension arm. I am wondering if someone can tell me or show me the proper routing of the hoses. One hose has a 90 degree fitting on it. I can't figure out where the 90 elbow should be located in relation to the bracket. Also the metal tubing on the valve end of the hoses is bent in a certain way but can be position several different ways. If I place the 90 elbow front side of the bracket it appears that the hose is too tight between the bracket and the control valve. If I try to mount the elbow rear side of the bracket it doesn't fit either. I would like to properly route the hoses per original factory routing. Can someone send me a photo of their 1970 mach 1 power steering hoses or does someone have a shop manual drawing or picture to help me out. Many thanks. Ken Testa, Long Island, NY
ken testa is offline
Old 03-14-2003, 01:47 PM
volrath
volrath's Avatar
find anything? i would look a mine but it is in storage. it will be a while before i get it out of there. i couldn't find anything eather.
volrath is offline
lincolnshibuya
12-08-2020 01:49 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
PaulH2
20
01-31-2016 09:48 AM
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
09-25-2015 06:58 PM
Quick Reply: 1970 mach 1 power steering
