'67 fuel gauge help please.
Old 09-28-2004, 11:34 AM
egomonkey
egomonkey's Avatar
Default '67 fuel gauge help please.
Hey there, I have a bit of a problem. I just got my '67 coupe, about a month and a half ago. But I haven't had much time to work on it. There isn't alot of big things to work on, the biggest is probably the fuel gauge. It always shows on empty, even after I fill the tank up all the way. And I'm wondering how I can fix this? I have a chilton book on my car, but it doesn't show too much in to depth about my problem. (I'm only 16, and I'm still trying to learn about cars). If anyone could help me this would be great. Thank you.
egomonkey is offline
Old 09-29-2004, 01:18 PM
Stepman
Stepman's Avatar
Default RE: '67 fuel gauge help please.
Crawl under your car at the front of the tank. There will be a wire going to the sending unit. (same location as the fuel line) Pull the wire off and connect it to a ground with a "jumper wire", turn your key on and watch your guage. Does it go to full now?
Stepman is offline
Old 10-02-2004, 08:28 PM
68GEETEE
68GEETEE's Avatar
As Stepman stated, it is most likely the fuel gauge sending unit located in your fuel tank. If its the original, you can bet its no longer working.
68GEETEE is offline
Old 10-02-2004, 09:42 PM
e40water
e40water's Avatar
My friend had the same problem on his 65 stang, He filled his tank full it showed always empty, We pulled the tank added a new sending unit, Works like a charm now.
e40water is offline
GimpyHSHS
19
12-19-2023 01:12 PM
jwog666
12-27-2021 08:09 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: '67 fuel gauge help please.
